GW-9100 HYDRO en imágenes
01http://lh3.ggpht.com/_w3CBCRfOIRg/S1mO_aXgaCI/AAAAAAAABO8/DkyFdcs1MGk/DSC03862.JPG
02http://lh6.ggpht.com/_w3CBCRfOIRg/S1mO_xL9d5I/AAAAAAAABPA/2vaqi9kiKs0/DSC03863.JPG
03http://lh4.ggpht.com/_w3CBCRfOIRg/S1mPAoDMKmI/AAAAAAAABPE/Pyw_NwUuvcU/DSC03864.JPG
04http://lh3.ggpht.com/_w3CBCRfOIRg/S1mPBQ9YIvI/AAAAAAAABPI/B5PScqP7t7k/DSC03865.JPG
05http://lh3.ggpht.com/_w3CBCRfOIRg/S1mPByQ-x3I/AAAAAAAABPM/UfmbHqve08E/DSC03866.JPG
06http://lh4.ggpht.com/_w3CBCRfOIRg/S1mPCqzQ8ZI/AAAAAAAABPQ/OdwEtyRN8F4/DSC03867.JPG
07http://lh5.ggpht.com/_w3CBCRfOIRg/S1mPDEh7-NI/AAAAAAAABPU/sarz_cRimd8/DSC03868.JPG
08http://lh6.ggpht.com/_w3CBCRfOIRg/S1mPELtEJbI/AAAAAAAABPY/ho-lY48XjZc/DSC03869.JPG
09http://lh3.ggpht.com/_w3CBCRfOIRg/S1mPE_Qmb_I/AAAAAAAABPc/kHW8JMGU7MU/DSC03870.JPG
10http://lh3.ggpht.com/_w3CBCRfOIRg/S1mPFhizi0I/AAAAAAAABPg/vp_hEWsOHEU/DSC03871.JPG
11http://lh5.ggpht.com/_w3CBCRfOIRg/S1mPGfo-LeI/AAAAAAAABPk/HdcrXLn_dLQ/DSC03872.JPG
12http://lh3.ggpht.com/_w3CBCRfOIRg/S1mPHH7JvPI/AAAAAAAABPo/B8YB91uWGns/DSC03873.JPG
13http://lh6.ggpht.com/_w3CBCRfOIRg/S1mPH0HpnqI/AAAAAAAABPs/2Lia3wdnlPE/DSC03874.JPG
14http://lh6.ggpht.com/_w3CBCRfOIRg/S1mPInNGwyI/AAAAAAAABPw/C9rIdmzUvig/DSC03875.JPG
15http://lh5.ggpht.com/_w3CBCRfOIRg/S1mPJUnOV4I/AAAAAAAABP0/Fq3xc-H-pi4/DSC03876.JPG
16http://lh3.ggpht.com/_w3CBCRfOIRg/S1mPKNTxQgI/AAAAAAAABP4/-iB-fqa6p2M/DSC03877.JPG
17http://lh4.ggpht.com/_w3CBCRfOIRg/S1mPK7Hv-eI/AAAAAAAABP8/hsk-o8RBcgA/DSC03878.JPG
18http://lh6.ggpht.com/_w3CBCRfOIRg/S1mPLkrmqzI/AAAAAAAABQA/w3VYPG35NgA/DSC03879.JPG
19http://lh6.ggpht.com/_w3CBCRfOIRg/S1mPMeEvv4I/AAAAAAAABQE/GLRME99m_0A/DSC03880.JPG
20http://lh5.ggpht.com/_w3CBCRfOIRg/S1mPNAMTcRI/AAAAAAAABQI/5MXcvzDwc_k/DSC03881.JPG
21http://lh4.ggpht.com/_w3CBCRfOIRg/S1mPNi14pyI/AAAAAAAABQM/vrePdsKgPjQ/DSC03882.JPG
22http://lh4.ggpht.com/_w3CBCRfOIRg/S1mPQrcYfmI/AAAAAAAABQY/HPvAXzQUJ9E/DSC03885.JPG
23http://lh4.ggpht.com/_w3CBCRfOIRg/S1mPShOgV_I/AAAAAAAABQk/xuudezCeyjk/DSC03888.JPG
Lo primero que tenemos que plantearnos, es perderle el miedo a abrir un G-SHOCK, porque son duros tanto por fuera como por dentro, y su complejidad nada tiene que ver con la simple manipulación de caja y módulo que vamos a realizar.
¿Para qué hacemos esto? - Se preguntará alguno:
Básicamente para lograr mayor legibilidad de pantalla tanto fuera como bajo el agua, donde se obtiene la eliminación del efecto espejo de cualquier reloj, esta es para mí la mayor de las ventajas, y la mejora en la pantalla que parece que mejora en contraste y nitidez.
http://lh3.ggpht.com/_w3CBCRfOIRg/SsNBWkuFWDI/AAAAAAAAA-M/tfKCDpoVQCM/DSC03799.JPG
http://lh4.ggpht.com/_w3CBCRfOIRg/SsNKK1Sx58I/AAAAAAAAA_E/W6ho1IrduIc/DSC03800.JPG
  • Para proteger si cabe todavía más las partes internas de nuestro reloj del ataque de los elementos exteriores que acaban por debilitar las juntas con el tiempo. Lo que implica que si el modelo elegido es solar, podemos decir adiós a revisar juntas.
    Otra de las razones, sería la de tener un reloj de equipresión, y así dejar en ridículo esos 200m de nuestro G-Shock de serie y convertirlos en 1000m o incluso más, claro que no podremos comprobarlo en casa, para esto no hay tutoriales. Esta es la razón más profesional y lógica de la transformación, pero quizás en nuestro caso sea la menos importante.
  • Y por último gracias a las propiedades físicas del aceite de silicona, una mayor estabilidad a los cambios de temperatura, que significarán que si antes era prácticamente imposible que se diera algún tipo de condensación en la pantalla, ahora es realmente imposible. Y un efecto que he comprobado, a temperaturas de -22ºC el visor del módulo ya no se congela, seguimos viendo como pasan los segundos uno tras otro. También he probado a 100ºC durante 30 sg. y parece que agunta. Eso sí la burbuja cuando lo achicharras a calor tiende casi a desaparecer, del mismo modo al sacarlo del congelador la burbuja duplicó su tamaño y es así como vemos que el aceite dilata y contrae y por tanto la necesidad de dejar esta burbuja en el interior.
                              PROPIEDADES FÍSICAS DEL ACEITE DE SILICONA:
                                                     Punto de inflamación: 300 º
                                                     Punto de congelación: -55 °
                                                     Coeficiente de expansión entre los 25 ° y 100 °: 9.45.10-4
                                                     Rigidez dieléctrica a los 25 ° en kV / mm: 18
Vamos a la faena entonces, ahora que tenemos claro que nos lanzamos a la piscina:
Unos simples destornilladores de precisión son suficientes, aunque si fuésemos profesionales (cosa que yo no soy) también unas pinzas plásticas para manipular las partes interiores del reloj (protector de goma trasero y módulo) aunque esto último no es necesario.
La primera fase es el desmontaje:
Primero de la correa y bezel, para mejorar la comodidad en la manipulación de la caja y
evitar marcharlas de aceite.
Ahora ya podemos desmontar la tapa trasera, retirándole los cuatro tornillos que la sujetan (tanto para aflojar como para cuando apretemos la tapa al acabar el trabajo, siempre ir en cruz y dando pocas aguas por tornillo, para evitar el sufrimiento de un tornillo por tenerlo totalmente apretado cuando los otros están sueltos)
Retirada la tapa, ya podemos observar el interior del reloj, veremos una tapita de goma justo debajo, con cuidado la deberemos retirar de manera vertical. Veremos que existen dos orificios en ella, uno deja sobresalir un muelle del módulo y otro una pestaña, estas partes hay que tocarlas lo menos posible y da igual para que sirven a nuestros efectos.
Ahora ya podemos ver el módulo que va encajado en el interior de la caja y que podremos retirar sin mayor problema ayudándonos de la punta del destornillador plano haciendo palanca en un sitio donde sea fácil introducir y hacer dicha palanca con suavidad.
Al retirar el módulo (en los modelos solares) veremos en la parte inferior debajo del bisel dos muelles de cobre que hacen el contacto entre panel solar y módulo, es otra de las partes a tratar con delicadeza. Si es solar pero no radiocontrolado encontraremos un espacio vacío en el módulo que si rellenamos con una trozo de espuma nos evitará hacer la famosa burbuja.
Segunda fase: Llenado de aceite.
Como se observa en las fotos es tarea sencilla y no entraña mayor dificultad, pero hay que tener en cuenta un truco; calentar previamente el aceite para que este esté en máxima dilatación y evitar la sobre presión que se produciría si lo metemos muy frió, en su mínimo volumen de expansión, y en verano, al tener el reloj al sol llegase a dilatar tanto que estallase el cristal o nos perdiera aceite por algún botón o la junta trasera. (Calentar en el microondas 2m. a máx. potencia el bote de 2oz sin tapa, no hace falta ramita de perejil, la temperatura final a la que introduciremos el aceite en la caja, es “caliente” entre 40º y 70º, que sería un buen margen pensando en un reloj en la playa al sol tirados en la toalla)
Un tema que se comenta en los posts es el caso de “los más extremistas” eliminar la antena de recepción en los módulos radiocontrolados y colocar un trozo de espuma, yo lo veo una chapuza descomunal:
  • Primero porque con dejar un poco de aire entre un botón y el módulo es más que suficiente -se explica aquí como-, en el caso del aceite de silicona el incremento del volumen por cada 10º de incremento en la temperatura, es de un 0,7% aproximadamente igual que en el resto de los aceites, lo que con respecto al volumen que en la caja aporta la antena es ínfimo.
  • Retirar la antena implica amputar una característica del módulo sin que suponga aporte alguno.
Por mi experiencia es suficiente con llenar la caja por la mitad y a continuación introducir el módulo. En algunos modelos el módulo y la caja tienen una guía de unión, en otras como este caso no. Al introducir el módulo hacerlo inclinado hacia un lado para que las patillas del módulo encajen con los botones de ese lado y después dejarlo caer hacia el otro lado y con la punta del destornillador meter hacia adentro las patillas para que no queden sobre los espárragos de los botones. De esta forma el módulo encajará por completo en la caja.
Ahora viene el truco de la burbuja, es más fácil de lo que parece. Si el módulo está bien encajado tal vez quede alguna bajo el cristal o tal vez no, a nosotros no debe importarnos. Veremos que como no llenamos del todo la caja con aceite algunos huecos de esta han quedado vacíos, pues lo que debemos hacer ahora es llenarlos todos menos uno que dejaremos tal cual, ahí estará la famosa burbuja que tal vez acabe por aparecer en pantalla o tal ver siempre quede oculta.
Casi por último ponemos sobre el módulo la junta de goma, prestando atención a que por sus orificios sobresalga el muelle y patilla que anteriormente comenté, esto también nos ayuda a dar con la colocación correcta.
Ya casi nos hemos ganado una cervecita, pero para ello tenemos que colocar la tapa trasera y apretarla con sus respectivos tornillos que apretaremos en cruz y lentamente para que si hay exceso de aceite fluya sin desplazar la junta de goma y evitemos pellizcarla. Al montar el bezel, en la mayoría de los modelos con tornillería de acero, ya que estamos con aceite, podremos aprovechar para aceitarlos y evitar su oxidación futura.
En el caso del GW-9100 con sus dos cristales y en cualquier otro G, el resultado a primera vista puede ser desalentador al aparecer micro burbujas, dos burbujas más grandes o espacios en pantalla en los que el aceite parece no haber llegado.
Las fotos están tomadas a las 12:30 del mediodía a las 18:30 las micro burbujas habían desaparecido y se había formado una bonita burbuja en el centro de la pantalla. 22:44h el espacio entre cristales está completamente lleno de aceite y tenemos una burbuja preciosa dando paseos por la pantalla.
Se puede acelerar el proceso, agitando el reloj igual que se hacía anteriormente con los termómetros de mercurio, cosas de la fuerza centrífuga, o atándolo a un hilo y haciéndolo girar, que es el sistema más cómodo, con esto se centrifuga el aceite y se concentran el aire eliminando las microburbujas.
Si la burbuja al cabo de unos días nos parece demasiado grande, sólo tenemos que levantar la tapa y añadir una gota de aceite y si es demasiado pequeña o tenemos dudas de su existencia, retiramos una gota con bastoncillo de algodón.
Tengo 4 hydros, en dos la burbuja ha desaparecido en otro es como el Guadiana que aparece y desaparece y en este de las fotos creo que me ha quedado demasiado grande con lo que voy a reducirla añadiendo una gota de aceite. Si sabemos que está, si llega a esconderse pues nada dejarla que se acomode donde le venga bien.
Como se puede ver por por la fecha del reloj, al día siguiente el aceite se había ya asentado y el resultado es el siguiente:
http://lh4.ggpht.com/_w3CBCRfOIRg/S1rDRWokBRI/AAAAAAAABRo/vcPTUQadMoM/DSC03891.JPG
El la siguiente foto ya he corregido, añadiendo un poco más de aceite:
http://lh3.ggpht.com/_w3CBCRfOIRg/S1rDTWQDFnI/AAAAAAAABRw/TGVTEBedoD8/DSC03893.JPG
Y aunque los más observadores vean que el día 22 ha sincronizado y el 23 con aceite no, poco tiene que ver el aceite y mucho el frente borrascoso que dejó caer agua por un tuvo toda la noche y evitó la recepción.
Con lo que acabo este ladrillo diciendo que se pueden quedar tranquilos los más tímidos a esta transformación. El G seguirá con todas sus funciones intactas.
Nota:
En las imágenes 22 y 23 puede observarse tanto en directo como provocando el efecto espejo bajo el agua que el aceite no había penetrado totalmente entre los dos cristales. Lo acaba haciendo como se puede comprobar en las fotos de la burbuja corregida.
http://lh3.ggpht.com/_w3CBCRfOIRg/S1w0rV4x5sI/AAAAAAAABUg/rL-fsayrVDY/DSC03897.JPG
En esta última foto se puede observar que la burbujita ha desaparecido, escondida tras el módulo y el reloj a vuelta a sincronizar sin problemas al mejorar el tiempo. Lo cierto es que la burbuja a la vista sólo vale para presumir ante los amigos, pero acaba por ser un incordio para ver la hora.
Espero que con estas explicaciones el que se decida a hacer un hydro vea que ni es difícil, ni comparta problema alguno para el reloj.
OTROS MODELOS HYDRO
http://lh5.ggpht.com/_w3CBCRfOIRg/S11PeWwi03I/AAAAAAAABWA/sS_nJ-G5mr8/DSC03828.JPG
TÉCNICA DEL CENTRIFUGADO
Logramos con ella dos cosas:
Primero dejar la burbuja dentro de la caja o tras el cristal para tenerla a la vista.
Segundo, podemos ver exactamente la cantidad de aire contenida en la caja, pasando gracias al centrifugado todo el aire al mismo punto.
PASO 1:
http://lh4.ggpht.com/_w3CBCRfOIRg/S113_YR1GAI/AAAAAAAABW4/E_LPXbJq6o8/DSC03901.JPG
Haciéndolo girar de esta forma pasamos todo el aire a la parte posterior del reloj, quedando justo tras la tapa trasera. Es más si nos damos maña podemos dejar la burbuja del tamaño idoneo y el resto del aire tras la tapa, con lo que el relleno de aceite y su eliminación está garantizado.
PASO 2:
http://lh5.ggpht.com/_w3CBCRfOIRg/S113_zPkDfI/AAAAAAAABW8/XTubBgvkAvo/DSC03902.JPG
Por el contrario si lo hacemos girar de este modo, todo el aceite quedará dentro de la caja y el aire que contenga tras el cristal, dándones la medida real del aire contenido en la caja, por lo que podremos comprobar que si hay una burbuja mínima tenemos un auténtico modelo de equipresión y si casi toda la pantalla es aire, todavía nos queda trabajo por hacer.
Fantástico post… estos días buscaré el aceite de silicona.
Sensacional !!! Gracias por este EXCELENTE tutorial !, lo del centrifugado es de lo mas original. !
Muy buena la explicación, tremenda currada.Esto se merece una
http://img144.imageshack.us/img144/2893/smil4733a04eb2ee2ca1.gif
, muchas gracias.
Lo que más complicado veo es dejar la burbuja de aire, que no sea ni muy grande ni demasiado pequeña… Pero gracias a este post me animo más a hacerlo, aunque todavia no tengo un G para ello. Muchas gracias por el post Ferrolano
¡¡IMPRESIONANTE!!
Tengo un 5600 igual que el que muestras en la última foto y creo que me voy a animar a hacerlo.
Veo que has utilizado un aceite de silicona específico para amortiguación de coches de RC con una densidad de 20, ¿es importante la densidad del aceite en cuestión o da igual? hay aceites desde 10 hasta 100…
Muchísimas gracias por compartir este tutorial!!!
Tooooma tooooooma. Uno de los mejores post que he visto ultimamente.
El efecto espejo lo recuerdo de jugar en la piscina con los casios ochenteros, después no he vuelto a observar el fenómeno.
Lo del aceite de silicona, no tenía ni idea. Un remedio inteligente y eficaz.
Yo no practico buceo, y apenas leo el reloj bajo el agua, ¿esto del efecto espejo lo sufren todos los divers? ¿Es normal que no lleven de fábrica soluciones como esta que propones?
Gracias por el post, y por el detalle y buena explicación.
El “efecto espejo” que igual tiene otro nombre, se produce en todos los relojes, sean o no divers.
Hay un POST, en otro foro de relojes, que habla sobre relojes que de fábrica aportan esta solución, pero evidentemente no cuestan 5€ como la mía.
Los cristales curvos disminuyes el rango de grados en los cuales hace ese efecto tambien.
Genial, ferrolano simplemente genial!!!
Muy bien explicado, vaya que el no haga un Hydro ahora no tiene excusa.:smiley:
Ese es el problema que tengo yo ahora, he visto de 10:20:30…200:300:500…5000:10000…
Las propiedades son identicas menos la densidad, cual es la densidad adecuada para nuestros propositos¿?
Cuanto mas denso mas aguantara los cambios de temperatura… pero si es muy denso el reloj va a pesar un cojon! :angry
Ademas si es muy denso sera mas dificil trabajar con el.
Usé 20 porque no encontré 10, cuanto más líquido mejor.
Estoy buscando uno super líquido para hacerme un analógico.
Nunca habia oido hablar sobre este sistema hasta ahora, simple pero muy efectivo. Muchas gracias por tu tutorial!!
enhorabuena tío!!! y gracias. Muy interesante el asunto.
oye, si haces el analógico pon fotos por dios. Tengo un aparato digital que mide el consumo con una precisión tremenda. Seria interesante ver el consumo de un analógico antes y después del aceite. A ver que incidencia tiene en la duración de la pila.
Una reflexión. ¿esto mejor solo para relojes solares no? Por que cambiar pila, habrá que hacerlo uno mismo.
¿donde decís que saco el aceite? Que voy a ahogar una miyota, pero ya.:stuck_out_tongue:
El aceite lo puedes comprar mismo en EBAY.
Mi gran duda en hacer un analógico es si el motor no se resentirá por la mayor resistencia al avance de las agujas segundera y minutera, porque la horaria supongo que sufrirá menos al moverse mucho menos.
Si tienes ese aparato y quieres lanzarte … yo encantado :inlove: :inlove:
Sólo dos ideas:
  • El aceite debería ser de densidad 10 o incluso 5 si se encuentra.
  • Al cerrar la tapa trasera si es de rosca, dejar la corona abierta para que el exceso de aceite escape por ella, dado que por la rosca no puede hacerlo.
Muy , muy interesante y muy bien currado, si señor…un placer su lectura…
el problema, que veo, así pensándolo un poco. Es que un 20bar con corona de rosca, en cuanto aflojes la rosca para poner en hora o mover calendario, seguro que chorrea. Así que mejor un 10bar o 5 bar. Que tienen otro tipo de junta. Aunque pienso que todos terminaran chorreando por la corona. Y mas con un densidad 5.
Pero voy a ver si encuentro un “densidad 5” y emborracho un analógico barato.
En principio, creo que lo mas “bonito” es dejar una burbuja chula en la esfera. Documentare el tema del consumo, es lo que puede decidir la viabilidad del asunto, para otros analógicos de más precio.
una miyota sin calendario,limpita y nueva, consume 1 microamperio justito y la pila dura de 15-18 meses. Normalmente los movimientos de cuarzo consumen entre 1-1.5 microamperios. Si consume mas de 2 ya se puede decir que “algo pasa”. Por encima de 4 microamperios la pila se la ventila enseguida, mas allá de 6 o 7 microamperios, el reloj no marcha ni con pila nueva. La pila no puede mover el rotor.
Resumiendo, si queda por debajo de 2 el tema es muy viable. por debajo de 3 viable, pero la pila durará 6 meses como mucho. Por encima de 4 no es viable.
Gracias por tus comentarios, saludos.
Tal y como son las coronas, habría que ponerlo en hora de canto y con la corona mirando hacia arriba…independientemente de la densidad del aceite que está claro que habría que saber como influye en el consumo de la maquinaria.
Mi intención es hacerlo con un ecodrive de cítizen para olvidarme del cambio de pila, pero es lo que tu dices, si el consumo se dispara quiere decir que el motor sufre y ahí ya no me convence el asunto porque no es lo mismo cargarse un reloj de 40€ que uno de 400€ para entendernos.
Tenía pensado comprar un casio analógico tipo G-101 o un Duro que no se disparan de precio y probar, pero no se si los resultados serían determinantes para pensar en hacerlo en un ecodrive.
http://lib8.store.yahoo.co.jp/lib/1more/g-101-1avdms-b.jpg
El tema de la burbuja, totalmente de acuerdo … que se vea, dado que en la contemplación del resultado también está la gracia.
Y que sea solar, porque hacer cambios de pila anuales es un coñazo con aceite de por medio.
La unica forma de saberlo a ciencia cierta, y poder tomar las decisiones consiguientes. son dos maneras.
Comprar dos relojes identicos, presuponer que consumen lo mismo (que es mucho suponer) hacerlo en uno si y en otro no, poniendo pila nueva a ambos. Esperar a que se acabe la pila.
Usar un tester profesional, que es lo que tengo yo.
http://i46.tinypic.com/vxjjx3.jpg
En esta imagen, el aparato esta testeando un movimiento de cuarzo en modo consumo y nos indica:
  • **que atrasa **
    -0.03 seg/dia (yo lo suelo poner en segundos/mes me hago mejor idea) varia bastante con la temperatura, donde mejor comportamiento tienen es en la temperatura del cuerpo humano. En este caso seria -1seg al mes, que seguramente en la muñeca, se quede en +0.5 al mes, que es ideal para un cuarzo.
  • que tiene un circuito de inibicion
    y que los impulsos de bobina son cada 1 segundo. Esto quiere decir que cada x segundos el reloj “inibe” un pulso para corregir precisión. Esto se hace para ajustar la deriva del cuarzo. es un poco largo de explicar.
  • que las puntas están suministrando 1.55voltios
    al movimiento.
  • Que el consumo total
    del movimiento es de 1.02 microamperios (perfecto)
Si consigo el liquido lo probare, ya que es un dato que es importante conocer con exactitud. Y a partir de ahi, ya se puede decidir con conocimiento de causa. Si alguno va a pedir liquido que pida dos botes y yo se lo pago.
saludos.
