http://i.ebayimg.com/00/s/NDc5WDUyOA==/$(KGrHqZ,!pgE7BcvkddwBO+M–gQ8w~~60_3.JPG
Tiene la caja cromada. ¿Que os parece?
Son 215 leuros. Quiero uno de estos pero no se si arriesgarme.
Otro par de fotos:
http://i.ebayimg.com/00/s/NDgwWDUwNA==/$(KGrHqR,!nwE-w(wSjEiBP-T8N29H!60_3.JPGhttp://i.ebayimg.com/00/s/NDc5WDU0Mw==/$(KGrHqV,!pcE7Bcvjlv2BO+M+Cm)yQ60_3.JPG
Descripcion del vendedor:
Russian Watch Chronograph SHTURMANSKIE !
Russian chronograph SHTURMANSKIE.
The gray background is decorated with the typical logo of the russian air force and the writing ‘stumanskie’ is printed in kyrillic letter on the upper half of the dial. The luminous hands and the ends of the indices are a soft shade of green in daylight and are perfectly radient in darkness.
The engraving on the back cover:SHTURMANSKIE
Movement:
Mechanical caliber 3133, hand-wound, diameter 31 mm, 23 Ruby jewels, shock protection, mean-daily rate from -20 to +40 sec/day, balance periode 21,600h, 42-hour power reserve with chronograph switched off, 37-hour power reserve with chronograph switched on.
Functions:
Chronograph, 30-minute counter, hours, minutes, seconds, day-of-the-month calendar.
Case:
Slightly rounded edges, diameter: 40 mm, height: 14 mm. For straps with 18 mm width.
Indicators:
Right side of dial: minutes counter, left side of dial: seconds counter, calendar at “6 o’clock”.
The watch is running well and keeps correct time.
Watch comes with black strap!
boxes aren’t present
made in 2005
These watches are assembled only at the Moscow watch factory.
Eso es un Franken amigo!!
No esta bien ninguna de las agujas, y a esa caja con bisel interno no le toca ese dial…
Echo en Frankenlandia!
Ninguna de las agujas es correcta.
Claro que alguno de sus relojes es excepción, pero por norma, y si me permitis el consejo…
pasen de “Ruscamera” !!! :beated:
Donde podria comprar uno de estos no franken?
Si te vale yo he encontrado esto, es nuevo a estrenar http://www.aviation-time.com/1320/sturmanskie_remakes_-_military
Gracias compañero; ¿Desde esta pagina había que pagar aduanas si no recuerdo mal de otro hilo?
Por cierto te has hecho con la mayoría de las piezas con las que sueño. Bueno algunas de las de tu colección ya las tengo, pero el Strela y el O´keah, maldita crisis.
En esa página no aceptan Paypal , , que peligro.
Gracias, ¿Puedes especificar un poco mas? Me he leído el hilo para datar los relojes con movimiento 3133, pero tanta información me desborda.
Esa esfera es reciente (basta mirar los detalles del los puntos luminosos)…
Mira uno correcto… (mira el color del dial, las agujas, los puntos luminosos…)
http://uhrforum.de/attachments/356357d1326648384t-vorstellung-altersbestimmung-sturmanskie-kaliber-3133-sturmanskie01_small4forum.jpg
Foto de uhrforum
Te pongo enlaces en que puedes ver bastantes modelos:
http://www.netgrafik.ch/airforce_watches.htm
http://www.kawarthadurhamkartclub.com/websiteSFarrell/index.html
https://plus.google.com/photos/113098239036073221216/albums/5729128497101829649/5729128637552790002?banner=pwa&pid=5729128637552790002&oid=113098239036073221216
https://plus.google.com/photos/113098239036073221216/albums/5665868840769645553/5665868996332252546?banner=pwa&pid=5665868996332252546&oid=113098239036073221216
El grabado de la trasera también echa para atrás…:ouch:
La suya:
http://i.ebayimg.com/00/s/NDgwWDUwNA==/$(KGrHqR,!nwE-w(wSjEiBP-T8N29H!~~60_3.JPG
Este es un modelo que he estado siguiendo también en internet…tenía un precio muy bueno…demasiado bueno para ser verdad :doubt:
Gracias a todos.
Voy a pasar buenos momentos gracias a esos enlaces.
Creía que había leído bastante de este tema, de hecho había leído bastantes post de Polmax3133, pero no me había percatado de que tenía ese enlace.
No se que hacer, comprarlo, ya se que no es original y que esta modificado o comprar uno en ebay que estará en mal estado y que le peguen un repaso y por lo tanto ya no sera original.
Depende de sí éres o no muy “purista” en esto de los relojes y se estás dispuesto o no a esperar el tiempo suficiente como para conseguir alguno…
Por exemplo, el modelo que kaik ha puesto arriba, se trata de un reloj supuestamernte destinado exclusivamente a la fuerza aérea, y que por veces se encuentra por Ebay…
Jope menos mal que al final no cai.La verdad es que lo ves tan nuevecito… Resulta luego que es un franken… gracias por el aviso amigos. Hay que ir con muchisimo cuidado, eso esta claro. Gracoas otra vez.
