me gusta todo de ese gwg,menos los numeros tan grandes…de todas formas tiene muy buena pinta,es un futurible.
bien,ya veo que nada de smarwatches ni leches en vinagre.vamos a estar aguantando modelos con triple sensor 3 baseworlds mas,por lo menos.no es que me importe mucho,claro,q a mi me gustan bastante.
ahi os dejo caracteristicas del gwg,sorry in english.
Construction
Shock-resistant; vibration-resistant
Performance
200-meter water resistance, low-temperature resistance (-10°C / 14°F)
Radio Frequencies
77.5 kHz (DCF77: Germany); 60 kHz (MSF: UK); 60 kHz (WWVB: USA); 40 kHz (JJY: Fukushima, Japan) / 60 kHz (JJY: Kyushu, Japan); 68.5 kHz (BPC: China)
Radio Wave Reception
Automatic reception up to six times a day (except for use in China: up to five times a day); manual reception
Digital Compass
Measures and displays direction as one of 16 points with the second hand; measuring range: 0° to 359°; measuring unit: 1°; 60 seconds continuous measurement; bidirectional calibration and magnetic declination correction
Barometer
Measuring range: 260 hPa to 1,100 hPa (7.65 inHg to 32.45 inHg); measuring unit: 1 hPa (0.05 inHg); atmospheric pressure change indicator (±10 hPa); barometric pressure tendency graph (past 20 hours graph display); barometric pressure tendency information (arrow indicates significant pressure changes)
Altimeter
Measuring range: -700 m to 10,000 m (-2,300 ft to 32,800 ft.); measuring unit: 1 m (5 ft.); manual memory measurements (up to 30 records, each including altitude, date, time); auto log data (high/low altitudes, cumulative ascent and descent of particular treks); altitude change indicator (±100 m / ±1000 m); other: relative altitude readings (-3,000 m to 3,000 m); measurement interval setting*3 (every 5 seconds / every 2 minutes)
*3 second for first 3 minutes only
Thermometer
Measuring range: -10°C to 60°C (14°F to 140°F); measuring unit: 0.1°C (0.2°F)
World Time
29 cities (29 time zones; daylight saving on/off, Home city/World time city swapping) and Coordinated Universal Time, auto switching / standard time and Coordinated Universal Time
Stopwatch
1/100 second; measuring capacity: 24 hours; measuring modes: elapsed time, split time, 1st and 2nd place times
Countdown Timer
Measuring unit: 1 second (maximum 60 minutes)
Alarm
5 independent daily alarms; hourly time signal
Other Functions
Full auto-calendar; 12/24-hour format; battery level indicator; button operation tone on/off; full auto double LED backlight with afterglow: 1.5 or 3.0 seconds; hand-concealment function (manual, auto: barometer / altimeter / thermometer function)
Power Source
Tough Solar power system (high-capacity solar-charging system)
Continuous Operation
About 23 months with the power-saving function*4 ON after full charge
*4 Display shuts off after a certain period in a dark location
Size of Case
59.5 × 56.1 × 18.0 mm
Total Weight
Approx. 100g
saludos
tony
