A raíz de un post de Santi … esos del “antes y después”, me sonaba raro un antishock en la rueda de escape, así que he ido rebuscando un poquitito.
Santi mostraba el uso del antishock en la rueda de escape:
http://farm3.static.flickr.com/2265/2098494337_e86a48fd48_o.jpg
http://farm3.static.flickr.com/2419/2099272468_9966e2113b_o.jpg
El antishock en la rueda de escape no es realmente necesario en términos de evitar la rotura del pivote, pero hay razones para su uso … Parece que los beneficios son múltiples:
- Usando algún tipo de antishock permite utilizar pivotes cónicos … de TZ:
The cylindrical pivot (1) has the advantage of simplicity, robustness, and low cost. The friction of the cylindrical pivot is relatively high compared to the two-jewel arrangement used with the conical pivot. This friction results from the relatively thick jewel hole (2) and the pivot shoulder rubbing on the backside of the jewel (3) on the bottom pivot.
The cylindrical pivot is used for the mainspring barrel and gear train of the watch. The balance wheel usually uses a conical pivot, as does the escape wheel in many finer watches.
(El pivote cilíndrico tiene la ventaja de ser simple, robusto y de bajo coste. La fricción es relativamente alta, comparado con un pivote cónico, etc., etc.)
The conical pivot (1) requires two jewels for a bearing, a cap jewel (5) and pierced jewel (6). Unlike the cylindrical pivot, the conical pivot has no “shoulder” and uses the cap jewel to determine end-shake of the wheel pinion (3). This arrangement provides lower friction than the single-jewel cylindrical pivot arrangement. Generally, friction on the conical pivot occurs only at the tip of the pinion on the lower cap jewel (3) or, in a vertical position of the watch (a horizontal position of the pinion) on the thin edges of the holes in the two pierced jewels (6).
The conical pivot is usually used on the balance wheel and, sometimes, on the escape wheel. The balance (and, when provided, escape wheel) anti-shock assembly uses a conical pivot with cap and pierced jewel.
… y como claramente explican con pivotes cónicos hay menos fricción … una mejor transferencia de energía al escape.
Algunos movimientos llevan antishocks funcionales y otros no (en ellos el rubí está fijo). Su función principal no es esa … aunque tampoco está de mas.
Aparentemente también ayuda a mantener el aceite en su sitio (por capilaridad … se vé fantástico en el video mas abajo), retardando también su oxidación.
Finalmente también parece tener la virtud de mantener el pivote centrado … como lo hace en el volante.
<object width=“425” height=“355”><param name=“movie” value=“http://www.youtube.com/v/KpII8WDZnYQ&rel=1”></param><param name=“wmode” value=“transparent”></param><embed src=“http://www.youtube.com/v/KpII8WDZnYQ&rel=1” type=“application/x-shockwave-flash” wmode=“transparent” width=“425” height=“355”></embed></object>
Aparentemente, el primer sistema antishock consistió en meter en reloj en una sucesión de cajas, la última cubierta por cuero. No muy útil para el vistazo casual a la hora !!
Después vino Breguet con su invención del “pare-chute” donde montaba el rubí en un “muelle” que permitía un cierto “juego” lateral. Obviamente esto era para relojes de bolsillo, y su uso no se generalizó … hasta que el reloj de pulsera hizo que verdaderamente se necesitase el antishock:
Preciosos “paracaídas”:
http://culture.hautehorlogerie.org/IMG/jpg/large-5-102.jpg
http://www.thepurists.net/Patrons/Members/AlbertoS/Breguet/Hayek/Tradition1_L.jpg
otro parachute algo mas tosco
Mucho mas tarde … en 1929, Wyler produjo su volante Incaflex (curioso donde los haya) donde los brazos o radios del volante con forma espiral actuaban como amortiguadores. Este es el hombre que se dediba a tirar relojes desde la torre Eiffel y otros edificios para demostrar la dureza de los mismos !!
http://www.wylergeneve.com/wyler_geneve/gallery/incaflex_2.jpg
De:
http://www.horlogerie-suisse.com/marques/wyler.html
Ya en 1933 Hans Marti patentó el por todos conocido Incabloc (parece ser que había en el mercado sistemas similares, pero Marti se llevó el gato al agua).
De aquí en adelante, la historia crece rápidamente con diferentes sistemas (todos bajo el mismo principio de funcionamiento) por un buen número de compañías:
Incabloc, Shock Resist, Super Shock Resist, Kif Trior, Kif “A” Flector, Kif Protechoc, Ruby Shock, Monorex 53, Simrex, Antichoc 102, Shock Stabil, Fixmobil,
Duofix, Parechoc, Novochoc A & B, Eterna, Unichoc, Cymaflex, General. Neutro Shock, Resomatic, Master Shock, Resochoc, Emo Antichoc, Brac, Cimier Lapanouse, Liengme Shockstop, Oris, Vibrochoc, Microflex, Bidlingmaier, Contrachoc, Durobloc, Forster , Inbterco, Intex, Hercules, Kienzle, Protax, Rufarex, Ultrabloc, Unisafe, Medaflex, Vibrax, Diac, Uwersi-Vufe,Diashock, Benrus, Combilager, Girocap, Lubrifix, Incastar, Bulova, Junghans, Cortebert Spirofix, Bigalu, DuroswingFarr-Intex.
… Y hasta aquí he llegado y espero que al menos os haya resultado curioso.
Ahora, cuando veo un muelle o un antishock en la rueda de escape … ya sé lo que veo !!
http://farm3.static.flickr.com/2085/2099684612_e1297e60dc_o.jpg
Gracias Pedro y Santi por estos post del antes y el después …
Salu2
Tony
