Tacticos Tawatec, no tienen mala pinta
TaWaTec Automatic M7 Blue Titan Diver
Descripción:
The TaWaTec Automatic - M7 - Titan Diver is the newest generation of tactical watches by SMW Swiss Military Watch Biel / Bienne. Over a year this titanium watch has been tested and optimized by different specialists from goverment units. The requirement of specialists for a big but light-weight titanium watch, you find now become realised in the TaWaTec Automatic - M7 - Titan Diver. The new design of this full titanium case guarantee a readability of the time in every condition at daytime or in total darkness at every time. The font on the dial “octil stencil” is “the” font which is used in the military sector and show the scope of military use. The first particularity you see on this operation watch is the crown on the “9” o clock position, which is applies for a high quality - authentic military watch. You will see this advantage might itself immediately if you wear a tactical or protection glove (e.g. pilotglove, sniper- shooter-glove, protective gloves in the “first aid” range etc.).The massive full titanium case and full titanium bezel, 300meter waterproof, sapphire crystal, oversize big 44mm case (without crown) 48mm with crown are the fist signs of this unique new TaWaTec Automatic - M7 - Titan Diver 300m. This big watch is light-weight about the use of black coated full titanium. Perfect reading of the time guarantees the big dial and the integrated H3 tritium illumination at every day and nighttime in every condition.
Details:
Clockwork: high quality Citizen Automatic Movement
Functions: 3 hands, Date
Waterresistance: to 30 atm/ 300 meters / 990 feet
Dial: black
Hands: red secondhand, white minute and hour hand
Size: 44mm whitout crown / 48mm with crown
High: 15mm
Case: titanium
Bottom: screwed, titanium
Crystal: sapphire, antireflectice coated
Crown: screwed, titanium, double o-ring
Bezel: unidirectional racheting titanium bezel, with blue H3 tritium illumination protected under sapphire crystal
Strap: Nato strap 22mm black
Warranty: 2 years on error free functionality of clock and clockwork.
10 years on unchanged optical readability.
Colors of the tritiumlights:
  • orange / above the number 12
  • blue / above the the numbers 1-11
  • blue on the min.- / hour - / second pointer
  • blue on the bezel protected under sapphirecrystal
  • mb microtec illumination / trigalight
http://www.tacticalwatchcenter.com/startpics/impressum-tawatec.jpg
http://www.tacticalwatchcenter.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file.jpg
http://www.tacticalwatchcenter.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/T/A/TAWATEC_M7_600.jpg
http://i171.photobucket.com/albums/u293/TheGren/Tawatec/divedk.jpg
TAWATEC E.O.Diver Tactical Blue
Descripción:
Details:
Swiss Made Quartz Movement;
Special features: Metal movement, repairable / Power saving mechanism with pullled out stem: Reduction of consumption approximately 70%
Waterresistance: to 20 atm/ 200 meters / 660 feet
Dial: black
Hands: red second hand, white minute and hour hand
Size: 46mm whitout crown
High: 13mm
Case: poly carbon fiber / antimagnetic
Bottom: screwed
Crystal: flat hardened mineral glass crystal, resists scratching
Crown: on 4 o’clock, double o-ring
Bezel: unidirectional racheting bezel with H3 tritium illumination
Strap: rubber strap 22mm black, on the double-buckle engraved logo
  • blue on the min.- / blue on the hour - / blue on the second pointer
  • blue on the bezel protected under crystal
  • mb microtec illumination / trigalight Switzerland
http://www.milwatches.com/tawatec/eod_blue/tawatec-dia-0002-02.jpg
http://www.milwatches.com/tawatec/eod_blue/tawatec-blue-0001-04.jpg
http://www.milwatches.com/tawatec/eod_blue/tawatec-blue-0001-02.jpg
TaWaTec Automatic ICS Black Titan Diver
Descripción:
The TaWaTec Automatic - ICS - Black Titan Diver is the newest generation of tactical watches by SMW Swiss Military Watch Biel / Bienne. Over a year this titanium watch has been tested and optimized by different specialists from goverment units. The requirement of specialists for a big but light-weight titanium watch, you find now become realised in the TaWaTec Automatic - ICS - Black Titan Diver. The new design of this full titanium case guarantee a readability of the time in every condition at daytime or in total darkness at every time. The font on the dial “octil stencil” is “the” font which is used in the military sector and show the scope of military use. The first particularity you see on this operation watch is the crown on the “9” o clock position, which is applies for a high quality - authentic military watch. You will see this advantage might itself immediately if you wear a tactical or protection glove (e.g. pilotglove, sniper- shooter-glove, protective gloves in the “first aid” range etc.).The massive black coated full titanium case and black coated full titanium bezel, 300meter waterproof, sapphire crystal, oversize big 44mm case (without crown) 48mm with crown are the fist signs of this unique new TaWaTec Automatic - ICS - Black Titan Diver 300m. This big watch is light-weight about the use of black coated full titanium. Perfect reading of the time guarantees the big dial and the integrated H3 tritium illumination at every day and nighttime in every condition.
Details:
Dial: black
High: 15mm
Case: black coated titanium
Bezel: unidirectional racheting black coated titanium bezel, with green H3 tritium illumination protected under sapphire crystal
Strap: diverstrap 22mm black, on the double-buckle engraved logo
  • green on the min.- / orange on the hour - / blue on the second pointer
  • green on the bezel protected under sapphirecrystal
The coloured operational principle of the TaWaTec Automatic - ICS - Black Titan Diver originates from the use in instruments from air and sea-navigation: The zero point of the titanium bezel is provided with a green H3 tritium tube. This H3 tube stands in relationship with the minutehand. This is illustrated in the lower picture, you see that the bezel is adjusted at a 3 o clock position. Therefore the TaWaTec Automatic - ICS - Black Titan Diver has a green H3 unit on the minutehand. The indices on 12 o clock is equiped with a orange H3 tritiumtube, which has a reference relationship with the hourhand. (a different colour in the 12 o clock position to the other indices is particularly importantly for the arm attitude and the basis for error free reading in the dark) for good intuitive reading we choose a orange H3 tritium tube on the hour pointer of the TaWaTec Automatic - ICS - Black Titan Diver.
The remaining hour indices (1-11) are secondary and equiped with blue H3 tritiumtubes. The second hand is equiped for an exact starting signal with a blue H3 tritiumtube (reference).
http://www.milwatches.com/tawatec/Black_Tawatec_Diver_day_500.jpg
http://www.milwatches.com/tawatec//B_TawatecAutomatikICS_night_500.jpg
Hombre, pues la verdad que buena pinta sí que tienen, aunque los de más de 44mm para mi son demasiado grandes.
La cosa es cómo se llamen en euros…
No estan mal, para mi los 44mm me vienen al pelo, lo que me descuadra del primero (que es el que mas me gusta ne acero) es que en la descripcion del reloj monta Miyota y en la esfera pone “Swiss Movement”.
¿Sabemos precios o enlaces que hablen de el…?
pues se llaman respectivamente:
800 $
250 $
630 $
Pues me parece que esta vez no a ser:eek: :eek: :eek: :smiley: :smiley: :smiley:
te descuadra porque lo hay en cuarzo suizo y en automatico japones y las fotos son del cuarzo… :smiley:
Pues a mi el Black Titan me encanta, pero lo veo un poco caro emho, una pena.
