Quizás alguno no conozca como funciona este magnífico reloj-instrumento, en este vídeo saldréis de dudas…
<object width=“425” height=“344”><param name=“movie” value=“http://www.youtube.com/v/HcE9dMYprbY&hl=es&fs=1”></param><param name=“allowFullScreen” value=“true”></param><param name=“allowscriptaccess” value=“always”></param><embed src=“http://www.youtube.com/v/HcE9dMYprbY&hl=es&fs=1” type=“application/x-shockwave-flash” allowscriptaccess=“always” allowfullscreen=“true” width=“425” height=“344”></embed></object>
Nota de prensa de Breitling sobre el proyecto de pasar a utilizar la frecuencia 406 MHz anunciada por la red de satélites COMPAS-SARSAT para el año 2009
ORIGINAL
Alert, Location, Rescue
The planned move to the use of 406MHz announced by the COSPAS-SARSAT satellite network for the year 2009 will improve alerting rescue personnel in the event of an emergency situation and provide an approximate position of the beacon. However, accuracy is within two miles using this frequency.
The usefulness and performance of the BREITLING Emergency therefore is in no way modified since in the second phase of localizing the victim, the 121.5MHz frequency still will be the only precise and reliable system to position the beacon within a few meters. This will continue to play a decisive role in the success of a rescue operation. Furthermore, all 406 MHz beacons operate and will be operating on two frequencies (406/121.5MHz).
In the event of an accident, the signal received by COSPAS-SARSAT is analyzed so as to calculate the approximate position of a crash and begin search immediately. It is only during the second phase, meaning during the search itself, that the use of the Emergency comes into play. Its micro-transmitter with its 48 power reserve is ideal for the close-range localization once the sector of the crash has been determined. As soon as the signal is activated, search aircraft pick up the 121.5 MHz frequency and can immediately home on the Emergency and proceed with rescuing survivors.
The aim of the BREITLING Emergency working on the 121.5MHz frequency is clearly to facilitate the location of the individual in distress and does not necessarily activate rescue operations but is a complement to airborne beacons.
Since launching our time and survival instrument BREITLING Emergency in the year 1996, no false alarm has been incited and its 100% reliability has enabled to localize and rescue about 20 individuals up to this day.
The Emergency instrument will be keeping its function as an additional and personal “life-saving-device” for many years to come and there is no intention to recall our watches and replace the frequency.
We hope these clarifications will help you understand the situation and wish you a lot of pleasure with your BREITLING Emergency watch."
RESUMEN
En cuanto a nuestro instrumento BREITLING EMERGENCY, somos conscientes de que el cambio de frecuencia suscita diversas cuestiones e inquietudes y nos gustaría darle las siguientes explicaciones:
ALERTA, LOCALIZACION, RESCATE.
El proyecto de pasar a utilizar la frecuencia 406 MHz anunciada por la red de satélites COMPAS-SARSAT para el año 2009, mejorará la llegada de las alertas a los servicios de rescate en caso de una situación de emergencia y proporcionará una posición aproximada de la baliza emisora. Sin embargo, la precisión usando esta frecuencia es de aproximadamente 2 millas. Por tanto, la utilidad y el rendimiento del BREITLING EMERGENCY de ninguna manera queda aminorada, ya que en la segunda fase de localización de una victima, la frecuencia de 121,5 MHz todavía será el único sistema fiable y preciso para posicionar la baliza emisora en un radio de escasos metros. Debido a esta circunstancia seguirá desempeñando un papel decisivo en el éxito de una operación de rescate. Además, todas las nuevas balizas que operaran en 406 MHz emitirán en ambas frecuencias es decir 406 y 121,5 MHz.
En caso de un accidente, la señal recibida por el sistema COMPAS-SARSAT se analiza con el fin de posicionar de manera aproximada el siniestro e iniciar la búsqueda de inmediato. Es durante la segunda fase, es decir, la de la búsqueda propiamente dicha, cuando el uso del EMERGENCY entra en juego, su micro transmisor con 48 horas de autonomía de funcionamiento, es idonea para la fase del proceso de localización cercana, una vez la zona de la tragedia ha sido posicionada. En el instante que la señal es activada, cualquier aeronave de búsqueda y rescate recogerá la frecuencia emitida en 121,5 MHz situándola con exactitud y procediendo a rescatar a los supervivientes.
El objetivo del BREITLING EMERGENCY que trabaja en 121,5 MHz es claramente facilitar la ubicación precisa de la persona en peligro y no necesariamente activar las operaciones de rescate, por ello es un buen complemento para las radio balizas de emergencia de las aeronaves.
Desde el lanzamiento de nuestro instrumento BREITLING EMERGENCY de señal horaria y supervivencia, en el año 1996, no se ha producido ninguna falsa alarma con él, y su 100% de fiabilidad ha posibilitado el rescate de unas 20 personas hasta el día de hoy.
El instrumento BREITLING EMERGENCY seguirá manteniendo esta función como adicional y personal “dispositivo salva vidas” por muchos años mas, por lo que no hay ninguna intención de retirar nuestros relojes ni de reemplazar su frecuencia.
Esperamos que estas explicaciones le sean útiles para entender la situación y le deseamos que disfrute por muchos años de su reloj BREITLING EMERGENCY.
