Casio protrek PRG 270-4
Vendo este magnífico Casio Protrek PRG 270-4, se encuentra en muy buen estado danto estético como de funcionamiento, va sin caja ni papeles.
eatures:
Tough Solar Power
100M Water Resistant
Low Temperature Resistant (-10°C/14°F)
Ver. 3 Triple Sensor (Altimeter/Barometer, Thermometer & Compass).
Tough Solar Power
Low Temperature Resistant (-10 C / 14 F)
Altimeter
Measuring range: -700 to 10,000 m (-2,300 to 32,800 ft)
Measuring unit: 1 m (5ft)
Manual memory measurements (up to 30 records, each including altitude, date, time)
Auto log data (High/low altitudes, auto cumulative ascent and descent)
Trek log data (up to 14 records of high/low altitudes, auto cumulative ascent and descent of particular treks)
Others: Relative altitude readings (3,000 to 3,000 m), Selectable measurement interval: 5 seconds or 2 seconds
Digital Compass
Measures and displays direction as one of 16 points
Measuring range: 0 to 359 degrees
Measuring unit: 1 degree
60 seconds continuous measurement
Graphic direction pointer
Bidirectional calibration and Northerly calibration function
Magnetic declination correction
Bearing memory
Barometer
Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
Display unit: 1 hPa (0.05 inHg)
Atmospheric pressure tendency graph
Atmospheric pressure differential graphic
Atmospheric pressure change indicator (arrow indicates significant change in pressure)
Thermometer
Display range: -10 to 60 C (14 to 140 F)
Display unit: 0.1 C (0.2 F)
Full Auto LED (Super Illuminator) Backlight with Afterglow
World Time
31 time zones (48 cities + UTC), city name display, daylight saving on/off
Sunrise/Sunset Data
Sunrise time and sunset time for specific date/ daylight pointers
5 Daily Alarms (4 one-time and 1 snooze alarm)
Hourly Time Signal
1/10 Second Stopwatch
Measuring capacity: 999:59'59.9"
Measuring modes: Elapsed time, split time, 1st-2nd place times
Countdown Timer
Measuring unit: 1 second
Countdown range: 24 hours
Countdown start time setting range: 1 minute to 24 hours (1-minute increments ans 1-hour increments)
Full Auto Calendar (Pre-programmed until the year 2099)
12/24 Hour Formats
Button operation tone on/off
Accuracy: +/- 15 seconds per month
Storage Battery: Solar Rechargeable Battery
Battery Level Indicator
Power Saving Function
Approx. Battery Life: 9 months on full charge (without further exposure to light)
Module 3415
:D:D
Precio 90 euros puesto en casa por correo certificado, se facilita seguimiento.
Y ahora unas fotos
https://lh5.googleusercontent.com/-qXgUWkhlGs4/VjC9G3wY0eI/AAAAAAAAGqw/KjvTI7uhM9c/w958-h542-no/15%2B-%2B1
https://lh5.googleusercontent.com/-HwnPWEHQQmw/VjC8_4A58KI/AAAAAAAAGqE/9L-eqpd2lJE/w958-h542-no/15%2B-%2B1
https://lh5.googleusercontent.com/-F-sKpzKGte4/VjC9DxY21LI/AAAAAAAAGqo/2dO0U75AVM4/w958-h542-no/15%2B-%2B1
Una ultima de la red que se ve mucho mejor que las mias:ouch:
Gracias por llegar hasta aqui y al foro por ceder el espacio.
seguimos
Buenos dias, rebaja al canto, 85 euros puesto en casa.
seguimos
Vengaaaa 80 euros puesto en casa, sólo de aqui al domingo.
Vendido
