Muy feo, no me gusta ni un poco! :inlove:
Foto de DragonJade @ WatchUseek
http://forums.watchuseek.com/attachment.php?attachmentid=51773&d=1181371835
En este thread.
En este thread.
Te ha entrado el virus G-Shock, ten cuidado que para este no hay cura…:D:P;)
El Gulfman es “feísimo”…:inlove:
Verdad, empezei por el dilema del 5600 frente al Mudman, pero después mirei los Wave Ceptor y ahora tengo cierto que voy a comprar el 5600 y un Wave Ceptor, probablemente este Gulfman. :ninja:
A mi tampoco me gusta el GulfMan…
A ver si veo uno a buen precio por Ebay
Nada, nada, horrible, espantoso… (si se encuentra “bien” por eBay no tardéis en poner el enlace ) :inlove: :inlove: :inlove:
Pues si feisiiiiimo…la unica pega es el 5 boton de la luz que no existe…siempre me ha gustado el 5 boton…es mas G.Bueno pues que me lo dieran…
¿que te parece este paulo…?
http://img72.imageshack.us/img72/1748/gw5600bcj12cl2.jpg
CASIO G-SHOCK WATCH
TOUGH SOLAR, ATOMIC
MEN’S MODEL# GW5600BCJ-1V
RETAIL PRICE: $150.00
EL Backlight (with Auto Light) An electro-luminescent panel causes the entire face to glow for easy reading. Auto Light automatically turns on the EL backlight when the watch is tilted towards your face for reading.
Shock Resistant Shock-resistant construction protects against impact and vibration. Solar Power A solar cell provides power for operation.
Multi-Band Atomic Timekeeping (2) (US/Canada/Japan)
World Time Displays the current time in major cities and specific areas around the world.
Stopwatch function (1/100 - 1.000HR) Accurate measurement of elapsed time with the touch of a button. The fraction indicates the unit of measurement, while the time figure indicates the maximum time measurement.
Countdown Timer Counts down from a start time specified by you. The value indicates the number of timers available, while the time figure indicates the maximum starting time. R indicates Auto Repeat, which automatically restarts timing at the end of each countdown.
5 Daily Alarms The daily alarm reminds you about recurring events with an acoustic signal at the time you have set. You can also activate hourly time signal that indicates each full hour. This model has 5 independent alarms for flexible reminders of important appointments. Snooze Feature Each time you stop the alarm, it sounds again after a few minutes.
Battery Level Indicator Indicator shows the current battery level.
Full Auto Calendar Allowances are made automatically for months of different lengths, in case date corrections for leap years are required.
12/24-hour Timekeeping Times can be displayed in either a 12-hour or 24-hour format.
Mineral Glass Hard glass resists scratching.
Stainless steel resin housing.
Stainless Steel Band.
200 Meter Water resistant. Perfect for free diving without scuba gear.
Warranty: 1 year.
Me gusta, pero prefiero el basico DW-5600E, por que ese no recibe senales en Europa. :sad:
me gustan los G con el quinto boton que esta en la letra G y que es para el illuminator…
que es eso de 5 band?? para que sirve<?
Este es feisimo, vamos que lo tengo :inlove: :inlove: y de lo feo que es soy el unico que lo quiere a rabiar
Otro pedazo de reflote!!!
Pero bueno, hay que fijarse un poco más, no???
Ah, por cierto, muy, pero que muy feo…tanto como el mío, jijiji.
+1 pero fijaos si es feo que yo no tengo ninguno…:sad: :sad: :sad: :sad:
feiiiiissssiiimmmooooo!!!
Por eso ya lo he tenido 3 veces…
saludossss
tan feo es el jodio que cuando lo compre… ¡¡¡ compre DOSSSSSSSSSSSSS !!! buaaaaaaaaaaaaaaaaaaa
…y tanto, que el hecho de no tenerlo no me quita el sueño…
Ufff…, yo iba a por él, pero me echó para atrás lo feo que era (¿o fue el precio? ). Me conformaré con su hermano el normalito…
bufff mira si es feo que vendi uno a un abejoro y me volvi a comprar otro al poco eso si multiband y con grafico de mareas. Aunque estoy pensando que este es mas feo todavia
pues si, es muy feo, es tan feo que si no queréis los vuestros yo hago un sacrificio y los adopto… así hacen compañia al mio
el multiband 5 es que el reloj sincroniza mediante ondas electromagnéticas (via radio) con un reloj atomico para ajustar la hora al milisegundo y esos relojes atómicos emiten la hora exacta desde 5 localizaciones, 2 en europa, 2 en japon y 1 en USA
A mi personalmente me encanta…hace tiempo que me lo queria comprar pero por avatares del destino tire por otros derroteros jeje pero no descarto su compra algun dia
