Hola. He recibido hoy uno de los casiotrones que lumber vendía y ni él ni yo sabemos como ponerlo en hora. ¿Alguien sabe? o ¿alguien sabe dónde buscar un manual?
El modelo en cuestión es éste.
Mira si te sirve:
Let’s say that the following shows the watch’s button layout. There are two on the right and one recessed button on the left.
**A
B C
In this guide:
{A} means press A
-{A}- means hold A
**So the way this watch works is like this: You can switch between regular timekeeping mode and ONE special mode with {A}.
The watch can only be set to use ONE of FOUR special modes at a time. It cannot use all four special modes at the same time!
Setting current time and/or date:
*When in time/date set mode, the selected digit will automatically advance by one every 2 seconds.
*When in time/date set mode, pressing B will abort time set mode.
set time:
When the [5] (50 second marker) is flashing, {B}.
Wait until the hour digit shows the current hour. (Remember, PM is indicated by a +] on the top right corner.)
{C} to move to the tens minutes digit:
Wait until the first minutes digit shows the current time.
{C} to move to the singles minutes digit:
{C} to finish setting the time.
Set Date:
While -{C}- {B}. This can be done at any second.
Wait until the month digit shows the current month.
{C} to move to the tens days digit:
Wait until the first minutes digit shows the current date.
{C} to move to the singles days digit:
{C} to finish setting the date.
To quickly compensate for 30 second errors in time:
{B} when [0]~[4] is lit flashing -> entire display will start flashing.
To adjust for watch being too fast, {A} when seconds is [0] [1] or [2]. This will round down the seconds to zero.
To adjust for watch being too slow, {A} when seconds is [3] [4] or [5]. This will round up the seconds to zero, advancing to the next minute.
To see day/date, -{C}- while in regular timekeeping mode.
To select your special mode:
while -{A}-, {B}
The digits will disappear and only the seconds will show.
Stop watch: {C} when [0] is flashing.
Counter: {C} when [1] is flashing.
World Time: {C} when [2] is flashing.
Time Memory: {C} when [3], [4] or [5] is flashing.
**All settings are erased if you switch to a different special mode.
**Once you select your special mode, it will be in indicated by a solidly lit (not flashing) seconds number. For example, if the [3] is solidly lit in regular timekeeping mode, the selected secondary function is World Time.
How to use special modes (secondary functions):
For all of these, {A} to enter special mode, {A} to return to regular timekeeping mode.
The following assumes you have selected the correct mode and have already entered the mode.
Stopwatch:
{C} to start stopwatch.
{C} to end stopwatch.
{C} to reset stopwatch.
Counter:
{C} to advance count.
-{C}- to reset.
World Time:
{C} to select the next city.
**To set the correct time zone/ time difference:
Select a city which time you already know.
{B}
Wait until the hour digit shows the current hour at that city. (Remember, PM is indicated by a +] on the top right corner.)
Wait until the first minutes digit shows the current time at that city.
The times at all other cities will be automatically calculated.
**All Cities are set to the same minute & seconds.
Time Memory:
{B}.
Wait until the hour digit shows whatever time you want to remember. (Remember, PM is indicated by a +] on the top right corner.)
Wait until the first minutes digit shows whatever time you want to remember.
{C} to finish setting the time memory.
**This is NOT an alarm. It’s basically like writing down some special time inside your watch.
Fuente: http://watches.gafortiby.com/how_to/Casio_Casiotron_Module_17_Instructions/
Que pillada!
Bueno tu Casiotron es este: http://www.casiodigitalwatches.com/casiotron/r-15b1-2-0.jpg
Es un R-15 Modulo # 15
Pues para ponerlo a hora, busca un botón hundido por un par de segundos, luego presiona el botón LIGHT para mover lo que ajustaras.
Si no tiene, Pues puedes usar el botón ST, mantén presionado ese botón, a ver que sucede.
Si no sucede nada, seguiremos buscando…
Vale. Creo que al menos ponerlo en hora lo he logrado. El resto de funciones se me antojan muy complicadas.
Gracías a los dos.
Creo que no es ese módulo, porque este mio tiene un botón arriba a la izquierda y dos a la derecha. Estoy echando un vistazo en esa página que me has dado, Nuno, a ver si lo encuentro.
Este tiene mucha más pinta de ser el que me vale. Por la tarde lo pruebo y os digo. Muchas gracías Nuno.
Ya está. Módulo 31. Muchas gracías a todos.
Buenas noches, lo más probable es que me haga con un R15; es el que no tiene luz y me gustaría saber un poco más del reloj, un saludo!!
