Swiss precision quartz movement Ronda 712.3, lubricated in oil bath.
FUNCTIONS
hours, minutes, screw-down crown.
CASE
made of AISI 316L steel with aged bronze PVD treatment, with a special manual treatment using various overlapping acids to create an oxidized and antiqued effect. The case is filled with a special oil that highlights the dial, creating the illusion of the absence of glass, with a more intense color effect and enhanced readability. Visible air bubble on the dial to compensate for temperature variations. Distinctive crown protector on the left. 44.8 mm diameter.
CASEBACK
innovative locking system (Locking Ring System) with quick battery replacement. Laser-engraved serial number and QR code. Scanning the QR code grants access to an exclusive digital experience.
DIAL
domed, painted metal with aged finish. Indexes and numbers treated with black superluminova. Hands painted metal with black superluminova.
CRYSTAL
high quality curved sapphire.
WATER RESISTANCE
50 mt, 5 ATM.
STRAP
laser-cut aged leather with natural process, cognac color. Handmade in Tuscany by expert craftsmen, with careful selection of leathers and materials and entirely Italian processing. Waxed cotton stitching. Width: 22/20 mm. Strap: ref. 9384/Z. AISI 316L steel buckle with aged bronze PVD treatment. Buckle: ref. 9598.
Y la pregunta del millon… pagaríais 1500€ por un cuarzo WR50m?
No entiendo, coger una caja de acero y darle un “tono” de bronce envejecido, haciendo parecer hasta sucio. No entiendo que el reloj se llame u-boat que este hidrolizado y que tenga wr50 m. No entiendo que por un cuarzo sucio pidan 1500€. Habrá gente que lo compre y presuma de él. La duda es que después de comprarlo si hay que limpiarlo o no.
Está de moda lo podrido y la suciedad.
Veo un montón de zapatillas con efecto desgaste y amarronadas por la suciedad…Ni lo veo en la moda,ni tampoco en la relojería .
Llevará de moda toda la vida.No te lo voy a debatir.Pero yo desde que tengo uso de razón,siempre he comprado zapatillas nuevas y me gusta que estén limpias y luzcan.
Y como aficionado a este tipo de calzado,pues es algo que no entiendo.Nunca me pondría unas zapatillas así desgastadas,con agujeros, efecto sucio…
Al ver el reloj,se me ha venido a la cabeza el tema del calzado.
Y luego una cosa es una pátina natural por el envejecimiento de la pieza.Que entiendo se quiera mantener,y otra cosa para mí totalmente diferente,es simular ese envejecimiento.Que para mí no hay por donde cogerlo.
Hace poco,se veía un reloj Pilot el cual si querías la caja envejecida y aporreada( literalmente golpeada y arañada a propósito), tenías que pagar mil euros de demasía…
No se,esto es como todo.Son gustos y modas.
Y cada uno tiene su gusto,y sigue la moda que más le conviene…
Es como las encuestas de los chistes, si la hago, las opciones serían, graficándolo:
Sector en rojo 65%: No.
Sector en azul 35%: No, pero en azul.
Estos de U-Boat no es que me caigan especialmente simpáticos ni el envejecimiento forzado sea algo que me llame estéticamente, pero sí que hay un ejemplo que me gusta de los amigos de Laco y por el que no me importaría hacer el desembolso correspondiente:
Efectivamente es lo primero que he pensado en los Romain Gerome.
Para empezar el pvd de bronce no lo entiendo pudiendolo hacer en bronce, segundo para qué el hidrolizado si solo es sumergible 50 mts, tercero, si se busca el estilo clásico, ¿le metes una pila?
Los U-boat siempre los he visto entre curiosos y estrambóticos, y me gana lo segundo.
Lo unico que le veo cierta gracia es el envejecido de la esfera y la correa muy guapa por cierto.
Y respondiendo a tu pregunta si pagaría por un cuarzo 1500 incluso mucho más como he pagado pero por ese despropósito, no.
Yo conocí esta marca cuando vi a Schwarzenegger usando uno, tienen un par de modelos que me gustan, pero este en concreto lo veo como un concepto absurdo, se ve que a mi alma de hipster la atropelló el pragmático que llevo dentro…
Como aficionado a los vehículos clásicos, no tan sólo acepto y respeto, sino que también me gusta hasta cierto punto, la pátina natural que un vehículo puede coger tras años de cuidadoso uso. Pero eso es una cosa, y otra muy diferente es simular que acabe de salir de la bodega del Andrea Doria… como un Audi TT que frecuenta mi zona y que está revestido de vinilo y aparenta ser puro óxido, me repugna, sinceramente.
A mi me gusta ir viendo cómo envejece el reloj a base de uso, pero comprarlo ya desgastado, no sé, siempre tendría la impresión de llevar algo falso, no le cogería el mismo cariño que le puedo tener a mis relojes más veteranos, con sus roces, pulidos, rayones… y lo mismo con el efecto bronce, coño, me gustan los relojes de bronce y algún día encontraré uno que me atrape y me toque llevarlo a casa, pero eso de andar imitándolo… meh!
